cpandya
BitStream generation fails with Aurora IP with DRC UCO-1 error when IP recompiles
I have added Aurora IP in my design with 4 Lanes and starting GT Lane is X0Y8. GT refclk selection is MGTREFCLK0 of Quad X0Y2. I am seeing error while generating binary file. Vivado is throwing error DRC UCIO-1 and when I open placed IO report, I see Lanes are not placed correctly. I see this issue only when I compile Aurora IP every time. If Aurora IP doesn't compile and use cache, then I don't see this error.
Can anyone help with this?
Thanks in Advance.
Tags (5)
rkhatri
Hi @cpandya,
It looks like location constraint is not specified for these pins rxn, rxp, txp and txn.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
cpandya
Thanks for reply @rkhatri ,
I am not explicitly writing constraints for these pins. I just mentioned starting GT lane in IP GUI but design doesn't take it according and throws error.
Let me know if I need to do it differently.
Thanks!
rkhatri
Hi @cpandya,
Please try to add the constraints for those pin explicitly and see if still errors are seen or not.
Rahul Khatri
