09-16-2011 12:24 AM
I am using xilinx ISE 10.1 Version.I am using widows XP. I am attaching one image here.I am getting this error.Pleasee see.How to solve it?
09-16-2011 01:22 AM
If you don't want to wait to troubleshoot this, I would recommend downloading and installing ISE 12.4 or ISE 13.2.
If it's a software bug, ISE 10.1 is not going to be updated, and you'll be installing a newer version.
If it's your PC which is messed up, or a problem with your ISE 10.1 install, you will need to re-install ISE to prove that ISE is (or is not) the problem. In any case, re-installing ISE is likely.
Just my wild guess, and I'm not a software support guy.
-- Bob Elkind
09-16-2011 01:33 AM
Hi eteam00,
Shall i install again after uninstalling this software?If i want to reinstall the software (tool), wether PC has to be formatted?
09-16-2011 02:35 AM
You don't need to uninstall 10.1.
Do not format your hard disk. Do not re-install Windows.
Just install 12.4. Change one thing at a time or your system will be a total mess and you will have no idea what caused it.
-- Bob Elkind
10-27-2011 12:33 AM
Have a look at the following AR.
http://www.xilinx.com/support/answers/30055.htm
Its better to upgade to latest version of tools there are many issues fixed in later versions of the IP.
