Vasundhara19
Block memory using IP catalog in Vivado
I am new to creating IP using Xilinx Vivado.
I have a .coe file that contains image pixel data in hexadecimal format. I attached the .coe in IP catalog->Other options->Memory initialization(as shown in image 1) and created a block memory(single port RAM).
Now, I have two questions: 1. where can I find the .coe file data in the block memory I created, how can I access the address locations where my data is stored and
2. Why is the block memory created in VHDL when I selected my target language as Verilog.
pthakare
Hi @Vasundhara19
#1 The data is stored from address "00"
e.g first entry in your .coe file corresponds to data at first address .
After the initialization you can check cell properties once sythesis or implementation is completed , Look of INIT_XX
#2  The source files for block memory generator are encrypted and you can only have wrapper file in VHDL , but the instantiation is available in verilog as well as VHDL.
Go to sources - IP-> instantiation files , you can find two files there , each one corresponds to VHDL and Verilog instatiation.
Vasundhara19
