ilam
Bram read
HI
I wrote 20 data by incrementing the address for 0,4,8and so on while reading from bram I can see the data of 4th address location on both 0th address and 4 address why it is happening like this 0th address data is missing while reading.
I am using true duel port ram
please find the image below
nathanx
True dual port bram has two ports, you need to be careful on address conflict, which is accessing the same address at the same time on different ports.
Please Kudo or Accept as a solution, If this Post helped you.
