Bringing up Aurora 64b66b IP with support logic in simulation
I'm using a Aurora64b66b IP in my design, and during my, when initializing the IP, I see no user_clk_out coming from the IP. lane_up and channel_up are also down.I am passing in init_clk and refclk1_in, reset_pb is being asserted for around 3.7us (similar to IP Example design). power_down s set to 0. pma_init mirrors reset_pb for 3.7us, which i see is a bit different (in duration) compared to example design. One difference, the IP is being simulated with the clock and other support logic in my simulation, which is a bit different from the example design (which has a wrapper module for these signals and then initializes the core without support logic). I'm trying to figure out why the core is not initializing? Am I perhaps missing any critical inputs?
Hi @spendyal ,
Issue was in configuration.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
Yes. That is correct. I was unable to figure out how to close this post.
