namsh
CPRI: Tcoretx and Tcorerx for GTHE3 (UltraScale)
I am referring to the CPRI v89 document. I can find information about GTYE3 Transceiver in Table 4-14, but I can't find any information about GTHE3 Transceiver.
Can I use the values in this table for Tcoretx and Tcorerx?
nmoeller
Hey @namsh,
The values for the GTHE3 transceiver delay are found in Table 4-10 of CPRI v8.9
For other transceiver-based implementations, the calculation is similar but uses the transceiver latencies for the relevant device.
So for the first column of Table 4-14, you would keep the 40UI from the logic delay component, but substitute 95UI listed for 16 bit GTHE3 delay from Table 4-10, for a total delay of 135UI TX delay in the 16bit configuration with a GTHE3 transceiver.
Nicholas Moellers
Xilinx Worldwide Technical Support
nmoeller
Hey @namsh,
Nicholas Moellers
