Can I send video over Aurora 64/66?
Aurora 64/66 AXI-Stream interface does not have TUSER signal.  TUSER is used to send Start of Frame by VDMA IP core.  So is it possible to send video over Aurora 64/66?
Neo
Community Manager
Community Manager
Re: Can I send video over Aurora 64/66?
This is covered in the XAPP link I shared with you.
You can also refer to the below snapshot for details.
Community Manager
Community Manager
Yes you can send it. Please refer to https://www.xilinx.com/support/documentation/application_notes/xapp1216-axi-chip2chip-aurora.pdf
 Tks for fast reply.
  Since it is using Aurora as phy, does that mean it can connect across short distance fiber optics as well?
Neo
Community Manager
Community Manager
Yes you can use it for short distances as well.
  I read the specs for AXI Chip2chip IP.  It does not have I/O port for AXI-S video stream.  Pls recommend how I can use it to send video frame buffer.  I am familiar with AXI VDMA but I do not know how to interface to this IP.
Neo
Community Manager
Community Manager
  Sorry about that,  I forgot about the xapp.  Tks
Neo
  The suggested solution converts AXI-S to a memory mapped write at destination.  I prefer to maintain the destination as AXI-S interface.  So instead of Chip2chip->Aurora ---->  Aurora -> Chip2chip  connection, I am thinking of keeping it as Aurora -----> Aurora connection.
  So to solve the problem of no AXI-S TUSER signal, I intend to intercept the AXI-S stream and generate a UFC or USER_K frame every time there is TUSER signal.  Then at destination, I will use UFC ot USER_K frame to re-produce TUSER signal.
  But my question is should I use UFC or USER_K interface.  From user guide I am able to understand the workings of UFC interface, and it seems I can use it for other purposes beside flow control.  But information on USER_K is sparse.
  Can you advise which interface should I use and why?
Neo
Hi wtneo@leica,
Could you get it working with UFC ? or you found some wayout to send TUSER ?
thanks
