zhch777777
Can clk_wiz use discontinuous clock?
Normally, the PLL is connected to a continuous clock. But I have a discontinuous clock that needs to track the phase. Can I use fb_out to generate a clock input corresponding to the edge to fb_in? Does the PFD in the PLL only examine the phase relationship between the two clock edges? or Still require a duty cycle.thanks
karnanl
Hello @zhch777777
No, a specific duty-cycle is required for both PLL/MMCM.
It is written in the datasheet of your device. ( Please read the datasheet).
For example this spec is for Kintex UltraScale+ (DS922)
Leo
Versal Blogs
karnanl
Hello @zhch777777
Leo
Versal Blogs
zhch777777
thanks.
 i had seen a PFD  design as shown below。Is PFD in PLL like this ? Or XOR gate design。
karnanl
Hello @zhch777777
Pardon me but we do not provide silicon architecture information at this level details.
If you do not follow clock-duty spec mentioned in the datasheet, your FPGA design may not work.
Kind regards
Leo
Versal Blogs
