zan_zhan@amat.com
Common Clock Built-in FIFO SRST in Virtex Ultra Plus FPGA.
Hi Everyone,
I have bunch of Common Clock Built-in FIFO in my design of Virtex Ultra Plus FPGA.
My question is About how to correctly handle SRST of Common Clock Built-in FIFO.
Assuming clock is always stable and SRST is synchronous reset,
Is it ok or safe to apply 1 clock cycle high pulse on SRST to reset FIFO?
If not, what is the correct way to reset FIFO?
Thanks a lot.
pthakare
Hi zan_zhan@amat.com
Atleast one clock cycle is okay .
for your reference please check the RESET section in PG057  -> page 136
https://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v13_2/pg057-fifo-generator.pdf
pthakare
