Continuous inputs to RAM Memory
Sir,
  I am working in Interleaver can't gave continuous inputs to RAM memory in continuous clocking any one tell me a
solution for this problem.Also,Is it possible to build interleaver memory in single port RAM.
vsrunga
Hi ,
Can you please clarify if your questiion is on BRAM or Interleaver ?
Xilins also has an Interleaver IP
below is the link
http://www.xilinx.com/products/intellectual-property/DO-DI-INTERLEAV.htm
This board is to help  BRAM &  FIFO users.
I am not sure what is your hurdle in writing  continously into BRAM, can you pease provide a pictorial view?
balkris
Core support continuous write in BRAM. You need to make sure you are asserting data , address and control signal correctly.
You can also use Interleaver IP as well
Thanks and Regards
Balkrishan
