Core generator and direct instantiation methods for using FIFO
HI everybody
what is differences between direct instantiation (instant XPM_FIFO_SYNC -->> ug953) and using core generator (IP catalog -->> FIFo Generator ) for instant a built in fifo in my design?
Hi @hrmt
The "Built in FIFO" is not supported through parameterized Macros. The supported fifo memory primitives are "Block", "Distributed"
and latest one is "ultra" which uses BRAM , Distributed RAM and Ultra RAM resources respectively.
The other difference are parameterized implementation is easy to migrate from one device family to other and to the latest IDE
(VIVADO versions).  XPM is inference based and FIFO generator is  instantiation based.
Reply if you have any queries, Give Kudos and Accepts as Solution
Reply if you have any queries, give kudos and accept as solution
Hi @hrmt
Hi @pthakare
what means  inference based?
what difference between  inference based and instantiation based? can you explain it?
Hi @hrmt
In this case when you instantiate a FIFO generator , you add an instance of the component to your HDL file.
The XPM is inference base  i.e when you use the XPM , the Synthesis tool will consider the memory_primitive attribute to determine which Primitive is to use to implement the FIFO.
The general difference is available here
https://www.xilinx.com/support/documentation/sw_manuals/xilinx10/isehelp/ise_c_imp_instantiation_and_inference.htm
Reply if you have any Queries , Give Kudos and Accepts as solution
