gszakacs
Instructor
Instructor
CoreGen FIFO Generator v6.1 - Behavioral model does not assert prog_empty flag
I looked in the known issues for FIFO Generator v6.1 and did not see this issue described
(http://www.xilinx.com/support/answers/35524.htm)
I generated a 40-wide, 32 deep dual clock distributed RAM FIFO for Spartan 6.  It has
a programmable empty assert threshold of 8.  When built with the behavioral model
the simulation shows prog_empty de-asserted after the first write, in fact one cycle
before the empty flag de-asserts, and then never re-asserted.
The structural model seems to show the proper behavior for the flag.
Also in the process of changing the core to provide a stuctural model, I found
that the default double-click action on existing IP within the CoreGen GUI is
to re-customize the core under the original project settings, not the current
settings which I had just changed.  This cost me an extra generation and
simulation cycle before I found out that the model had not changed.  In
the previous versions of CoreGen, the actions for an existing IP showed up
in the main window.  In 12.1, the actions have been pushed down the page
to where you need to scroll down to find them.  This is why I tried to re-customize
by double-clicking the IP.  After finding that a right-click on the IP offered the
options I needed (and also highlighted the default action so I saw where
the previous generation went wrong), I also found the actions in the main
window.
Gabor
-- Gabor
matttay
Hi, I've also just encountered a prog_empty issue with FIFO generator in ISE 12 for spartan sc3s400 256
I just deleted an older FIFO that was working as expected so that I could use the new memory generator. I set it the same as the previous fifo, with separate clocks. The FIFO is 32 wide, 64 deep. The prog empty thresh was set to to 32. Fall through enabled.
In sim, the prog_empty starts asserted (expected). After 6 writes to the fifo it goes low (unexpected). I changed thresh to 62. Same behavior. The write clock is about 10% slower than the read clock. But no reads have been done yet.
Cleaned project files, tried again. Same.
gszakacs
Instructor
Instructor
It sounds like the same bug.  My FIFO was also first word fall-through.  I would suggest
changing the Coregen project options to generate a structional simulation model.  At least
in my case the structural model worked as expected.
Gabor
-- Gabor
