Aparna_MK
Creating a custom IP peripheral to communicate with Zynq PS
Is it possible to create a custom IP peripheral (other than AXI peripheral) and send signals to it through Zynq PS? Is it possible to make connections between 2 different axi slave peripherals?
dpaul24
@Aparna_MK ,
AXI what? AXI4 full, AXI-Stream,..... ?
Depends on what do you mean by signals. A custom IP peripheral can send interrupt to the PS and in this case it is a signal which does not need an AXI style interconnect.
Connections using the AXI i/f? No...definitely not!
Because AMBA AXI protocols are Master-Slave based protocols. So how do you think two AXI slaves can talk to each other?
Connections using other ports....yes.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dpaul24
@Aparna_MK ,
