Divider core precision problems
I am trying to use the divider ip core. (v5.1 latest with vivado 2019.1.2)
Here are my exact configurations:
Algo type: radix 2
Operantd: signed
Dividend width: 16 Has Tuser, Tuser width: 1
Divisor width: 16
Fractional / Fractional width: 8
Optimize for performance, nonblocking
Latency automatic.
When I try to divide 300 by 200, I get 1.25 in simulation (0140 hex). What's wrong? I've attached the test bench.
module top_level_tb();
    logic clk =0;
    logic signed [15:0] a;
    logic signed [15:0] b;
    logic signed [15:0] c;
    logic dividend_valid = 0;
    logic divisor_valid = 0;
    logic result_valid;
    logic tuser_in = 0;
    logic tuser_out;
  // clk has 50% duty cycle, 10ns period
    always #5 clk = ~clk;
    initial begin
        #10;
//        a <= 16'b1111010100110110;
//        b <= 16'b1111100001100011;
//        a <= 16'b1111111110011100;
//        b <= 16'b1111111111111100;
        a <= 300;
        b <= 200;
        dividend_valid <= 1;
        divisor_valid <= 1;
        tuser_in <= 1;
    end
    div_gen_0 uut(
        .aclk(clk),
        .s_axis_dividend_tvalid(dividend_valid),
        .s_axis_dividend_tdata(a),
        .s_axis_dividend_tvalid(divisor_valid),
        .s_axis_dividend_tuser(tuser_in),
        .s_axis_divisor_tdata(b),
        .m_axis_dout_tdata(c),
        .m_axis_dout_tvalid(result_valid),
        .m_axis_dout_tuser(tuser_out)
endmodule
Participant digitate
Re: Divider core precision problems
I have not used the divider core myself, but the documentation for it (pg151-div-gen) says that  both the quotient and fractional results have a sign bit. So 0x140 is correct.
