Shikhar
Does Xilinx provide ARM Cortex IP for Kintex/Virtex
Does Xilinx provides any FPGA optimized and/or friendly versions of ARM cores for the FPGA implementation.
I found some information at below link but not sure how to use it. It does show CM1, CM3 in the image on slide 15.
https://www.xilinx.com/publications/events/developer-forum/2018-frankfurt/bringing-the-benefits-of-cortex-m-processors-to-fpga.pdf
Would like to know which cores are provided and what is the max synthesis frequency for these cores.
Or, is it specific to zynq family as shown on the below link.
https://www.xilinx.com/products/silicon-devices/soc.html
dpaul24
@Shikhar,
Did you go through the link you have posted?
If yes, then you should have found the link below...
https://www.arm.com/resources/designstart/designstart-fpga
which says "Cortex-M1 and Cortex-M3 soft CPU IP for use on FPGA designs for prototypes and commercial deployments."
Find out and read the data sheets....all such infos should be there!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dpaul24
@Shikhar,
u4223374
Advisor
Advisor
Xilinx doesn't (even for Zynq*), but I think ARM does - see here:
(*) Zynq isn't an ARM IP core, it's a full ARM Cortex-A series application processor that's permanently implemented on the chip (ie it's not in the programmable logic). In fact, the Zynq chips would be more accurately described as ARM processors with an FPGA connected to them, rather than FPGAs with embedded processors.
Shikhar
Thanks for the reply the previous link was not working for me.
designstart.arm.com/fpga
This worked:
