inaik
Doubt in connecting Bram to customized ip in Vivado
I am trying to connect Block Ram to a customized IP which adds 1 to the input ( using IP integrator). I am facing some issues in connecting Block ram and my ip. Also, which block should I use for connecting ,memory generator or controller? Please help me with the connections.  Screenshot (482).pngScreenshot (483).png
florentw
Hi @inaik
Your connection is a bit weird. How do you control at what address the data is read/written?
You can control the BRAM either at the BRAM controller level (if your IP can create AXI transactions) or at the BRAM directly.
But you need to control the full interface (AXI or BRAM_PORT) in both cases. You cannot just connect the data path...
Florent
