Dual port blockram with different width on each port
HI,
I am looking for a module like RAMB16 where i need the Rd/Wr width on Port A to be 4 bits whereas the Width on PORT B to be 8 bits. i implemented the logic but i am getting "0000" as read from Port B always whereas port A works fine
Praveen
HI,
You can use a memory generator as dual port ram with port a side as 4 bit and port b side as 8 bit. you can even specify the initialized vectors. you can specify the type of memory for building like blockram etc.
Thanks for reply, but i cannot use that because i need to use different init values for different projects and thus every time using the vivado memory generator will break the automation flow.
Usually for such applications we create a single memory instance and initialization vector is stored in flash. during power on the data is retrieved from flash into the memory. in such cases the bit file remains same.For different project only the init file gets stored into the flash, which can be selected from the GUI if the flash interface established.
Once again thanks for the reply. But as said earlier we are not using GUI anytime either during generating the bitfile process or  during uploading of bitfile, we use highly automated flow where human intervention is not there. I need a simple way where i can have a dual port ram with 4 bit on PORT A and 8 bits on PORT B, so that i can use script to add INIT values at RTL level and kick off the process, same as the INIT values are present in the attached file with standard RAMB blocks
Hi @praveengoyal
Use Xilinx Parameterized Micro . These are the alternative for block memory generator.
 Refer to the Libraries user guide for Instantiation and attribute definitions.
 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug974-vivado-ultrascale-libraries.pdf
Reply if you have any queries , Give Kudos and accept as solution
Thanks for the document, this looks to be the correct IP i would need to instantiate in my design. Where can i find a example instantiation of the same module in my install directory.
Once again thanks.
Just to check i should be able to pass the init Values to the module in the instantiation like i have done in the attached file.
Hi @praveengoyal
You can find the instantiation in Language template or Libraries user Guide (UG974).
The .sv of the Macro  is available at
C:\Xilinx\Vivado\2018.1\data\ip\xpm\memory
Reply if you have any queries , Give Kudos and Accepts as Solution
Is it possible to pass the init values like in RAMB36 instead of passing as a file as in below instance
   RAMB36E1 #(
      // INIT_00 to INIT_7F: Initial contents of the data memory array
      .INIT_00 (256'h000000000000000000000000108eeeee717fffffffffffff1f0db00009753110),
      .INIT_01 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_02 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_03 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_04 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_05 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_06 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_07 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_08 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_09 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_0A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_0B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_0C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_0D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_0E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_0F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_10 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_11 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_12 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_13 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_14 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_15 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_16 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_17 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_18 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_19 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_1A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_1B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_1C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_1D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_1E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_1F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_20 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_21 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_22 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_23 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_24 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_25 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_26 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_27 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_28 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_29 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_2A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_2B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_2C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_2D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_2E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_2F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_30 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_31 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_32 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_33 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_34 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_35 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_36 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_37 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_38 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_39 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_3A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_3B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_3C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_3D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_3E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_3F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_40 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_41 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_42 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_43 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_44 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_45 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_46 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_47 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_48 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_49 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_4A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_4B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_4C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_4D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_4E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_4F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_50 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_51 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_52 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_53 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_54 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_55 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_56 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_57 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_58 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_59 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_5A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_5B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_5C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_5D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_5E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_5F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_60 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_61 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_62 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_63 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_64 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_65 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_66 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_67 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_68 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_69 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_6A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_6B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_6C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_6D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_6E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_6F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_70 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_71 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_72 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_73 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_74 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_75 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_76 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_77 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_78 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_79 (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_7A (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_7B (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_7C (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_7D (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_7E (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .INIT_7F (256'h0000000000000000000000000000000000000000000000000000000000000000),
      .READ_WIDTH_A(4),        // 0-72
      .READ_WIDTH_B(9),        // 0-36
      .WRITE_WIDTH_A(0),        // 0-36
      .WRITE_WIDTH_B(9),        // 0-72
      .WRITE_MODE_A("WRITE_FIRST")
   u_RAMB36_0 (
      .CASCADEOUTA(),
      .CASCADEOUTB(),
      .DBITERR(),
      .ECCPARITY(),
      .RDADDRECC(),
      .SBITERR(),
      .DOADO(rdata[3:0]),
      .DOPADOP(),
      .DOBDO({rdata_bd[35:32],rdata_bd[3:0]}),
      .DOPBDOP(),
      .CASCADEINA(1'b0),
      .CASCADEINB(1'b0),
      .INJECTDBITERR(1'b0),
      .INJECTSBITERR(1'b0),
      .ADDRARDADDR({addr,2'b0}),
      .CLKARDCLK(clk),
      .ENARDEN(~cs),
      .REGCEAREGCE(1'b0),
      .RSTRAMARSTRAM(1'b0),
      .RSTREGARSTREG(1'b0),
      .WEA(4'b0),
      .DIADI(),
      .DIPADIP(),
      .ADDRBWRADDR({addr_bd,3'b0}),
      .CLKBWRCLK(clk_bd),
      .ENBWREN(~cs_bd),
      .REGCEB(),
      .RSTRAMB(),
      .RSTREGB(),
      .WEBWE({~wen_bd[1],~wen_bd[0]}),
      .DIBDI({wdata_bd[35:32],wdata_bd[3:0]}),
      .DIPBDIP()
Hi @praveengoyal
No , it is not possible to pass the Init values of each address.
Reply if you have any queries, Give Kudos and accepts as solution
Thanks, Could you please then send the format for the INIT MEMORY FILE so that i can use that method to initialize the memory.
Hi @praveengoyal
The extension is .mem.
File format must be ASCII and consist of only hexadecimal values organized into the specified depth by narrowest data width generic value of the memory.
For example, if the narrowest data width is 8, and the depth of memory is 8 locations, then .mem file content is as below temp.PNG
Where "AB" is the 0th location and "78" is the 7th location.
So if i want to have a TDP memory with PORTA as 32 bit wide  and PORTB as 64 bit wide can i have the following
10020000,
10000401,
10000925,
100009ab,
100009bd,
100009cf,
100009d1,
00000000,
00000000,
00000000,
00000000
