brun.olivier06
Error compilation MIG DDR2 with Spartan 3 AN
Hello every one ,
I want create an interface with DDR2 and FPGA so I have use the MIG for insert a DDR2 in the project but when I compile the project, 2 error display:
Synthesize XST --> OK but warning
Implement design:
                        Translate --> OK
                         Map --> 2 Error
ERROR:PhysDesignRules:760 - Incompatible programming for IO standard. IO
ERROR:Pack:1642 - Errors in physical DRC.
If some one has meet a this problem or has an idea I wait your reponse
Thinhs
brun.olivier06
If you have the same error in your project you must set in the MIG interface: DQS# enable --> disable(1)
brun.olivier06
weiwei1983
   I  set the dqs# disable by modifying the  signal ext_load_mode_register,of which the value is 0010000000000 ,but the same error  still  Exists.
   I hope the good  solution. Thank you !
