Error creating a project
I am new to the computer engineering field, my backround is in math, that being said, I have downloaded Vivado however when trying to create the tutorial project, I cannot, I don't seem to have  c:\xup\digital\sources\tutorial. Any help is appreciated.
@vicctorguajardo
Welcome to FPGAs and to the Xilinx Forum!
It looks like you are trying to use tutorials from the Xilinx University Program, which you should talk to your professor about.
Meanwhile, you may find the following links helpful when learning about the FPGA toolset called Vivado.
https://www.xilinx.com/video/hardware/getting-started-with-the-vivado-ide.html
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug910-vivado-getting-started.pdf
Cheers,
Mark
