Ethernet SGMII and aurora clock sharing
I am using AXI Ethernet Subsystem IP for SGMII and aurora IP on the same GTH of Artix 7 FPGA. I am configuring Ethernet as core design and sharing the clock to aurora.
When I see in ILA tx_lock is happening but lane_up and channel_up is not happening.
I am also attaching the block design picture for reference
Raghu
I'm doing the same thing. "sync_clk gose as txuserclk for A7 GTP" ,"user_clk goes as txuserclk2 input to GTP".
So I think they should connect to userclk_out of ethernet subsystem.
