scrooty
Example design and testbench not generated for "1G/2.5G Ethernet PCS/PMA or SGMII"
I'm generating the IP core "1G/2.5G Ethernet PCS/PMA or SGMII"  (pg047) and I don't seem to be getting an example design or a testbench as promised in the product guide (June 24, 2020).
Am I doing something wrong?
Or am I just misunderstanding what kind of example/testbench I could expect?
My flow is;  I am running Vivado 2019.2 gui and creating the IP in the "Manage IP" option.
Apologies if this is a dup. of some other issue - I did check and only found a similar issue for a different IP dating back to 2013 (and the solution in that issue did not work for me).
Thanks for reading,
Garrett.
adem369
If you want to open example design and test bench you should right click to IP and select "Open IP Example Design.."
adem369
scrooty
Hi Adem369,
I feel pretty silly now for missing that!    But thanks a million for your reply.
Scrooty.
