FFT Scaling scheme
Hi all,
  What is Scaling scheme,and what is the use ? how to give the value for N=4096,
Scaling is needed to prevent overflow. Scaling schedule tells the engine to scale the output after certain stages. Please read page 25 and 57 of this document for the detailed explanation https://www.xilinx.com/support/documentation/ip_documentation/xfft/v9_1/pg109-xfft.pdf
Hello @kapildev
As @baltintop   mentioned, Table 4-3 described the scaling in details.
kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
