chennan
FIFO simulation problem
I am simulating a FIFO in my design with structural model. However, in the simulation, the dout remains XXX even if the empty flag indicates that the data is written into the FIFP. Here is the timing table in the simulation. I think I must made some very stupid mistake since this is the first time I use FIFO. Please help me!
Thanks!
Chennan
chennan
Here is the setting of the FIFO
balkris
You need to check the warning generated by tool. It seems all the output data are XXX. this only meant core is not instant properly or your project corrupted any how
Thanks and Regards
Balkrishan
