Fatal Error xil_printf.h,xil_types.h and xparameters.h not found error in vitis software
we are getting the Xilinx library files (xil_printf.h,xil_types.h and Xparameters.h) in the Vitis software build. we are validating the JESD204B IP. We have created the MicroBlaze project for configuring the AD device. when we build the project we are getting all the Xilinx library header files not found errors.
pavan_619@
Hello @swathi
I think vitis 2020.1 is having some issues in Windows system.
Out of many reasons for this issue one potential issue could be the workspace path.
If it is too long these errors might appear. (Max 250 characters in Windows I guess)
Check the path once it may help.
You can also try what @adem369 mentioned.
Pavan
Accept as solution if it resolves your issue. Give kudos if it is helpful
adem369
It is a bug of Vitis/SDK, try Re-generate BSP Sources or create new project.
pavan_619@
Hello @swathi
Pavan
