joginder200109
Fixed point to 2qn conversion
i am having a float variable which is converted to 32 bit fixed point using the Float point ip of xilinx.now i want to generate cos and sin values for that variable using cordic ip.but input of cordic ip is in the format of 2QN where as i am having data in 32 bit fixed point format.how can i convert the 32 bit fixed point variable to 2QN format.any help will be appreciated.
example:
my variable is .5 rad which is converted to 0x3f000000.now i want to use this value as input for cordic to get cos and sin of .5 rad
thank you
joginder200109
i got the solution...from float i convereted to fixed point in the required format using floating ip which can be used directly for the cordic ip
tedbooth
The "XQN" data format is described on page 31 of the CORDIC v6.0 Product Guide:
https://www.xilinx.com/support/documentation/ip_documentation/cordic/v6_0/pg105-cordic.pdf
You will need to simply convert your fixed point format to match the XQN format expected by your cordic IP.
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
joginder200109
Can you provide any example of conversion to 2QN.I am not able to get any conversion algorithm
joginder200109
drjohnsmith
As a general comment, floating point in an FPGA leads to very very big and probably slow designs.
in a CPU , the same hardware is re used multiple times to make a single floating point answer,
e.g. in C, you design a 32 step floating point cordic, you get a single adder.
In an FPGA , if you design 32 step floating point CORDIC, you end up with 32 floating point adders , 32 times the area / power
