hadee
Floating-Point IPcore maximum clock
My Block design has IPcore <-> Floating IPcore <-> DMA <-> Zynq
I use floating ipcore to convert from floating point to fixed precision
I can use maximum clock as 200MHz from FCLK0 and it is worked perfectly.
When I try to use 220 or 250 MHz, I have got the wrong results. So Can i assume that maximum clock for floating IPcore is 200MHZ?
baltintop
Voyager
Voyager
Hi @hadee
Did the design pass timing when you specified the clock frequency as 220MHz or 250MHz in the constraints? If yes then it shouldn't fail on the hardware.
hadee
Thank you for answer,
I think you're right. My design failed to meet the timing requirements.
Anyway, when I decrease speed to 100MHz and I still got the timing problem but the IPcore is working.
The problem is here.
I have arrays of 4 dimensions as memory block in IPcore.
From the picture, The problem is in the path that connect to ram_reg.  Do you have any idea how to fix it?
baltintop
Voyager
Voyager
Hi @hadee
Can you share the timing report?
hadee
Yes, here you are.
baltintop
Voyager
Voyager
Hi @hadee
Those are some beautiful paths. All you have to do is pipeline your logic a bit in order to decrease the logic levels, which are not that high really, or choose a different implementation strategy.
