vhdlveri123
Frame gen and frame checker
I am trying to transfer data between two Aurora IP both in duplex mode. Do i need to instantiate frame checker and frame gen for both the master and slave Aurora IPs?
rkhatri
Hi @vhdlveri123,
Yes if you want to test both the paths then frame checker and frame gen are required both the side.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
rkhatri
Hi @vhdlveri123,
Rahul Khatri
