General error IP-Flow 19-3554
when I use ip core jesd204b and complete up-date, there is an error about vivado commands
[IP_Flow 19-3554] GUI update of parameter PARAM_VALUE.TRANSCEIVER failed.invalid command name "getTransceiverType"
but i dont know the parameter position. thanks
Fresh
yes sir,that guy met the same error with me, and he didn't find out the solution about it. He perfered to ignore this error.
Fresh
Hi 527114591@qq.com ,
Have you tried to reset the output products and then regenerate the output products?
If not please try and check.
Raj
