mjl-0708
How to check address conflict of True Dual Port RAM on Virtex4 devices?
I generated True Dual Port RAM in CoreGen, and access the DPRAM on two side.
When I write data on one side and read on another side at the same address, and how to check the conflict.
 The IP has no conflict flag.
balkris
You can run the simulation and check the  generated warnings. You can also refer Memory Collsion section and Address overlap condition mention in product guide..
Thanks and Regards
Balkrishan
mjl-0708
When I simulate, warning appears at when one side write and the other read the same address..
balkris
Please refer Collision Behavior section in PG058 page 60
Thanks and Regards
Balkrishan
