How to do a behavior simulation of PLL generated from clocking wizard?
Hi, I'm a new one using Vivado, and  recently, I'm trying to learn how to achieve behaviour simulation of PLL generated from clocking wizard(20MHz to 240MHz). But I encountered some questions, I need your help.
The source document is shown as below:
module NOT_gate(
input in,
//input reset,
output out
//    assign out = ~in;
clk_wiz_0 pll(.clk_out1(out), .clk_in1(in));
endmodule
The testbench:
module simulation(
    reg clk = 0;
    always #50 clk = ~clk;
    wire out;
//    wire reset = 0;
    NOT_gate NOT(.in(clk), .out(out));
endmodule
And the simulation results:
Thanks for helping me.
Hi @Leaner ,
To generate a 20MHz clock stimulus, it should be:
always #25 clk = ~clk;
And before the your module "simulation" definition, you have to specify the timescale:
`timescale 1ns / 1ps
Then, run the simulation longer than 20us to wait for the generated clock being locked.
Hi @Leaner ,
Thanks for your reply, and now, I can get right results!
But, I have a new questions about the results, the simulation result is as follows:
 The output of PLL is ok after about 3.3us. How to understand the results between 0 ~ 3us?
Hi @Leaner
That's how the MMCM/PLL works. It must cost some time to achieved phase alignment within a predefined window and frequency matching within a predefined PPM range.
LOCKED will be asserted after the output clock gets stable if it's enabled in the IP.
Thank you very much, I get it.
Do you know which user guide documents cover the principle of PLL(including explanation of the reset, locked, etc)?
Thanks for your reply.
Hi @Leaner
UG472 for 7-ser devices, UG572 for US/US+ devices.
PG065 for the Clocking Wizard IP.
Thanks!
Didnt expect to get a direct answer so soon! Thank you!
Do you meet the same problem?
