ghkdkrtks
How to include floating point IP(adder,multiply....) in my VHDL code?
No Block Design!
In Vivado 2109.1.2
How to include floating point IP in my VHDL code?
There is no in Zynq-7000 Libraries Guide and Language Template !
nathanx
In Vivado IP catalog, find the floating point IP, click "customize IP", configure the IP, click "ok" button to generate the IP, find the "*.vho" file in the generated IP folder, copy the content from the *.vho file to your design, which is to instantiate the IP in your design.
Please Kudo or Accept as a solution, If this Post helped you.
nathanx
