adam_mira
How to link jesd204 PHY to a specific clock?
In short:
How can I connect two jesd204 PHYs to the same QPLL output?
More information:
My goal is to instantiate two jesd204 PHYs using two GTH3 channels in the -same- quad.
The ref clock to both of the PHYs goes through QPLL0, so the ref clock port called "QPLL0_REFCLK".
With one PHY there is no problem. I'm connecting MGT_CLK to the port and its work as expected.
With two PHYs I'm connecting MGT_CLK to both ports but the "Place design" stage fail.
My question:
Thank you,
Adam.
roym
When you put 2 designs into the same quad both designs will instantiate a GT_COMMON for the QPLL and an input buffer for the refclk.  Since they are sharing these resources you must remove and input refclk buffer and the GT_COMMON from one design and wire the refclk buffer output and GT_COMMON outputs from the other design to drive the orphaned lines in the first design.  You will need to get the input buffer and the GT_COMMON into the example design to accomplish this.  I'm not sure how easy this is with the JESD IP.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
rkhatri
Hi @adam_mira ,
There is an AR which may be helpful.
https://www.xilinx.com/support/answers/65228.html
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
