briankincaid
How to recover DMA S2MM Direct (not S/G) without losing data
I have a system where I am receiving a datastream across S2MM that I use DMA to forward to memory.  The AXIS datastream does not have a 'TLAST' signal.  The packet size is known by the processor in real time, so it will set up a specific DMA transfer, for example 1024 or 4096 words.
Without TLAST, I expect the DMA to throw an Internal Error (Status bit 4) that I catch when the transfer has completed.  I will then restart the DMA for the next transfer (the incoming data never stops).
I have not found any sequence that will clear the error so I can restart the DMA without going through a Soft Reset (Control bit 2).
My problem is that the Soft Reset is flushing a large number of samples from the incoming stream, probably ~100.  I cannot tolerate this in my system.  Do you have any suggestions?
dgisselq
@briankincaid,
So far, I've only seen two solutions to this problem:
  1. Wrap the Xilinx S2MM DMA in a separate piece of logic that adds TLAST when appropriate
  2. Use a (non-Xilinx) S2MM implementation that doesn't depend upon TLAST.
Dan
dgisselq
@briankincaid,
Dan
briankincaid
Dan, I appreciate your response.  Your website is incredible.
-Brian
dgisselq
Thanks!  Incidentally, I discussed some of the problems with the S2MM core in this article.
Dan
