namnninh
How to sync chipscope to the design
Hi;
   I  want to sent input data through  USB platform interface (Chipscope pro) to the FPGA to test the design.
  How I can set up clock from the FPGA to sync with the USB cable speed?
   The  user clock of the design is 50Mhz and the USB cable speed is set up at 12Mhz.
Any help is appreciated.
NN
luisb
Have you considered using a CE pin to a BUFG?
bassman59
Historian
Historian
@namnninh wrote:
Hi;
NN
That's not at all how ChipScope works.
