katrenoopur
How to write in and out from fifo in VHDL using xilinx ISE
I am trying to create FIFO in VHDL, 16 word depth and 4 bit width, I'm not able to write in and out from fifo. Kindly help me in this. It seems like programm is not entering into the process. Signals that I am using is not updating. I am using Xilinx ISE IP Core to instantiate the FIFO . Asynchrous reset with value 0 is used.Here is the code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.NUMERIC_STD.ALL;
entity fifo_practice is
    generic (
    addr_width : integer := 4;          -- address width
    data_width : integer := 4);         -- data width
   Port
    (       clk : in  STD_LOGIC;
                rst : in  STD_LOGIC;
                din : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
                full: OUT STD_LOGIC;
                empty: OUT STD_LOGIC;
                test: OUT STD_LOGIC;
                dout : OUT STD_LOGIC_VECTOR(3 DOWNTO 0)
end fifo_practice;
architecture Behavioral of fifo_practice is
COMPONENT fifo1_module1
  PORT (
    clk : IN STD_LOGIC;
    rst : IN STD_LOGIC;
     wr_en : IN STD_LOGIC;
    rd_en : IN STD_LOGIC;
     dout : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
     full : OUT STD_LOGIC;
    empty : OUT STD_LOGIC
END COMPONENT;
--signal full : STD_LOGIC  := '0';
--signal empty : STD_LOGIC := '0';
signal wr_en : STD_LOGIC := '0';
signal rd_en : STD_LOGIC := '0';
constant depth : integer := 2**addr_width;
signal readptr,writeptr : std_logic_vector( addr_width-1 downto 0); --read and write pointers.
signal full0 : std_logic;
signal empty0 : std_logic;
begin
    --full <= full0;
    --empty <= empty0;
module1_fifo1 : fifo1_module1
  PORT MAP (
    clk => clk,
    rst => rst,
    din => din,
    wr_en => wr_en,
    rd_en => rd_en,
    dout => dout,
    full => full0,
    empty => empty0
fifo0: process(clk,rst)
    begin
        if rst = '0' then
            readptr <= (others => '0');
            writeptr <= (others => '0');
            empty0 <= '1';
            full0 <= '0';
        else
            if rising_edge(clk) then
                if (writeptr + '1' = depth-1) then
                    full0<='1';
                else
                    full0<='0';
                end if ;
                if (readptr = writeptr ) then
                    empty0<='1';
                else
                    empty0<='0';
                end if ;
                if wr_en='1' and full0='0' then
                    writeptr <= writeptr + '1' ;
                end if ;
                if rd_en='1' and empty0='0' then
                    readptr <= readptr + '1' ;
                end if ;
            end if;
        end if;
    end process;
end Behavioral;
Tags (4)
