Observer scsi
[IP_Flow 19-3461]
AXI BRAM controller has errors in Vivado 2016.4 :
[IP_Flow 19-3461] Value '134219776' is out of the range for parameter 'Memory Depth(MEM_DEPTH)' for BD Cell 'axi_bram_ctrl_1' . Valid values are - 512, 1024, 2048, 4096, 8192, 16384, 32768, 65536, 131072, 262144, 524288, 1048576, 2097152, 4194304, 8388608, 16777216, 33554432, 67108864, 134217728, 268435456, 536870912, 1073741824
[BD 41-1273] Error running pre_propagate TCL procedure: ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
::xilinx.com_ip_axi_bram_ctrl_4.0::pre_propagate Line 30
[BD 41-241] Message from IP propagation TCL of /axi_bram_ctrl_1: set_property error: Value '134219776' is out of the range for parameter 'Memory Depth(MEM_DEPTH)' for BD Cell 'axi_bram_ctrl_1' . Valid values are - 512, 1024, 2048, 4096, 8192, 16384, 32768, 65536, 131072, 262144, 524288, 1048576, 2097152, 4194304, 8388608, 16777216, 33554432, 67108864, 134217728, 268435456, 536870912, 1073741824
Customization errors found on 'axi_bram_ctrl_1'. Restoring to previous valid configuration.
Re: [IP_Flow 19-3461]
Hi @scsi
The error message is correct, please refer to page-9 in https://www.xilinx.com/support/documentation/ip_documentation/axi_bram_ctrl/v4_0/pg078-axi-bram-ctrl.pdf for supported depths.
For help on changing depth, Refer to AR https://www.xilinx.com/support/answers/66103.html
Deepika.
Hi @scsi
Is your query answered?
Deepika.
Visitor igortf
@vemulad
Hello, I get the same issue. I create a custom memory part with 2gb. But the SDK show only 1gb, which I used before. How can I pass the 2gb to SDK? I try change the 1G of mig_series7 (attach), but don't work. The 0xBFFFFFFF become 0xFFFFFFFF and conflict with axi_bram_ctrl_0.
Thanks in advance.
