dor_shmilovich
IP Utilization Database
I would like to know if there is a database for the utilization of all the IPs in the IP catalog.
I would like to make a rough calculator to easily check the percentage of the utilization of a design against the chip capacity.
Is there any API to use to get the utilization information of all the IPs easily without looking for all the IPs manually and type it?
Thank you for your help,
florentw
HI @dor_shmilovich
No I do not think there is any API. The way to check the resource utilization for an IP is to check at its product page on Xilinx.com
Florent
florentw
HI @dor_shmilovich
Florent
