Independent Clock FIFO's Post-Synth Timing Simulation,Post-Synth Function Simulation and Behavior Simulation are different
Dear  forums,
    I used FIFO Generator of IP Catalog at Vivado 2015.2 to generate a  Independent Clock FIFO in which read data width and write data width are different.However, Post-Synth Timing Simulation,Post-Synth Function Simulation and Behavior Simulation are different.But Behavior Simulation is exactly what I want.Please see it as below.
din is the input of write data for FIFO,and din is a "wire".assgin din = {datain4,datain3,datain2,datain1};
As above,doutdata is the read data of FIFO and doutvalid is the output valid signal.It is exactly correct.
As above,this is Post_Synth Functional Simulation,The first eight doutdata are correct and last four datadata  are incorrect.
As above,this is Post-Synth Timing Simulation.The first din which is {16'd207,16'd206,16'd205,16'd205} is not as output.
    I am confused where is wrong.
    By the way,Post-Synth Functional Simulation is the same as Post-Implementation Functional Simulation.And Post-Synth Timing Simulation is the same as Post-Implementation Timing Simulation.
   Please see the customization of FIFO as below.
Last,I would like to post my Xilinx files to be modified by you,Thanks.
'buffer1_top.v' is the top file of my module.
'test.v' is the file for simulation.
Re: Independent Clock FIFO's Post-Synth Timing Simulation,Post-Synth Function Simulation and Behavior Simulation are different
1. Try to use the latest Vivado version and re-generate the IP.
2. Change the simulator to Vivado Simulator.
3. Delay all the fifo inputs by 1/4 clock cycle to check it.
