AndreasBMadsen
Instantiating Xilinx IPs in VHDL code
I have been wondering for a long time if there is a way, in Vivado, to instantiate any Xilinx IP from the IP Catalog directly from a piece of VHDL code. Without ever opening the IP Integrator. I have not been able to find an answer for this question so far.
Thanks in advance.
bruce_karaffa
When you generate the IP, make it global, not out of context.  Look in the folder for that IP.  You will see a .vho file.  This will give you examples of how to declare the IP component and how to instantiate it in your code.
bruce_karaffa
AndreasBMadsen
Hi @bruce_karaffa
Thank you for your answer. What exactly do you mean by "generating the IP"?
AndreasBMadsen
Never mind. Found out. Thank you for your help.
