pallania
Inter FPGA RIOs Channel up problem
I am working on Virtex-5 and Virtex-7 FPGAs . There are x4 RIOs between them. When i am doing both codes in ISE14.7 i am able to see laneup and channel up. But when i have shifted to vivado for virtex-7 i am not able to see channel up, lane up is coming. Can you please let me know what may be the issue. I am using aurora8b/10b ip core.
Thanks & Regards,
Pallani.
rkhatri
Hi @pallania ,
you can check the IP changes in below link:
https://www.xilinx.com/support/answers/54367.html
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
