Observer dcho
Interlaken max data rate at 6 Gbps VCU118
Hello -
I am working on a VCU118 and I am using the interlaken core embedded in the hardware.
I have the interlaken implemented and everything but unfortunately, the data rate that i am getting is very slow compared to the proposed data rate on the documentation.  My configuration is below:
I am only able to get a max data rate of 6 Gbps PER lane or about 24 Gbps total for all four lanes.
On the documentation, it proposes 25 Gbps PER lane and 100 Gbps total for four lanes but i am not able to get even close to that.
I have tried many different configurations but they all give me a max data rate of 6 Gbps PER lane.  I have tried the in band and out of back flow control, burst mode, and different burst lengths but nothing has gotten me above 6 Gbps PER lane.  This max data rate has been observed in both vivado simulation and hardware.
Thank you.
Re: Interlaken max data rate at 6 Gbps VCU118
Hey @dcho,
How did you come up with the 6Gbps number?
I ran the example design with your settings and see data on the GT clocking changing every 38.78 ps or ~25.7 Ghz.
Can you give more detail?
Nicholas Moellers
Xilinx Worldwide Technical Support
Hey @dcho,
Is this using the example design? Can you check what the data rate is if you right-click the IP and select "Open IP Example Design"?
Nicholas Moellers
Observer dcho
Yes it is with the example design.
Hey @dcho,
Nicholas Moellers
Observer dcho
Hello -
Sorry i was making a mistake in my testing environment.
I was able to resolve this issue.
Thank you.
Hey,
That's great! Glad you got it worked out.
Nicholas Moellers
