JESD204 Tx No tx_tready
I am trying to get the JESD204B up and running, I can not get the tx_tready to come alive. I've copied the example test bench exactly as far as I can tell. Clocks and resets all there, configured as example. Can not get to work in sub class 0 or 1. Any help out there. Already did the google thing.
Paul
Hi @phg,
Are you using example design?
Have you tested the design in simulation?
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
