08-07-2018 11:50 AM - edited 08-07-2018 11:51 AM
I upgraded a working design from Vivado 2017.3 to Vivado 20181. My block design contains a JESD204B_PHY core operating at 125MHz. All the clock inputs to the JESD204B_PHY have a FREQ_HZ property of 125MHZ, but the output clock pins (rxout_clk and txout_clk) have a FREQ_HZ property set to 0.0.
When I validate the block design, Vivado reports an mismatched clock frequency error between the JESD204B_PHY rxout_clk and the BUFG_GT it is driving.
[BD 41-238] Port/Pin property FREQ_HZ does not match between clk_wiz_0/clk_in1(125000000) and util_ds_bug_0/BUF_GT_O(0.000)
Again, this design passed validation in Vivado 2017.3, since the rxout_clk and txout_clk pins have their FREQ_HZ property correctly set to 125MHz.
Why does Vivado 2018.1 not assign the correct frequency to the rxout_clk and txout_clk pins on the JESD204B_PHY?
08-20-2018 08:11 AM
Xilinx tech support found a work-around. When configuring the JESD204_PHY, the Line Rate parameter for the transmitter and receiver must be a floating point value, not an integer. Note, this issue exist in 2018.1 and 2018.2.
08-07-2018 01:25 PM
how did you update the core ?
I thought there were some big design changes ,
have hunt through AR for 18.1 and 18.2
08-07-2018 01:43 PM
I used the Reports > Report IP Status tool to upgrade all the IP. I also tried deleting the IP and then re-adding it.
The 2018.1 Vivado Release Notes has this:
JESD204 PHY (4.0)
* Version 4.0 (Rev. 2)
* Bug Fix: Corrected an issue where numerical rounding could occasionally result in incorrect frequency being set on tx/rxoutclk ports in IP integrator.
Perhaps the bug fix made it worse.
08-20-2018 08:11 AM
