jtanko12
JESD204B checksum
Can please someone tell me what checksum is sent over the lane during ILAS
from the JESD204 Tx? I am using JESD204 (7.2)
The Rx side is a DAC (AD9152) that expects the checksum as:
"lower eight bits of the sum of the following fields: DID, BID, LID,
SCR, L - 1, F - 1, K - 1, M - 1, N - 1, SUBCLASSV, NP - 1,
JESDV, S - 1, and HD"
OR
the sum of some register values on the DAC related to the JESD configuration.
Thanks a lot,
Jakab
jlarkin
The JESD204B spec defines the checksum (FCHK) as the modulus 256 of the sum of Configuration link parameters: BID, CF, CS, DID, F, HD, JESDV, K, L, LID, M, N, N', PHADJ, S, SCR, SUBCLASSV
jlarkin
intriple2018
Hi, how can I obtain the DID/BID/JESDV and LID from Xilinx JESD IP? The Datasheet Says its located in ILA0->ILA3 Registers, however these registers are not readable nor writeable for TX. I am trying to establish link with AD9172 DAC.
jlarkin
These values are in ILA Config Register 3, and if you look at the register map in PG066, you can see that this register is R/W for TX.  Look at ILA Config Register 3 for more details about what values are R, W, or R/W.
intriple2018
Thank you,
That was definitely my fault.
For some reason, I thought the ILA3 is not readable.
Seems to be OK according to the Datasheet.
jlarkin
Excellent, I'm glad you found that information useful.
