apogeedbkxilinx
JESD204B clocks from MMCMs
AR#71575 (https://www.xilinx.com/support/answers/71575.html) describes how to connect JESD204 cores for synchronization of ADCs.  Will this setup synchronize properly if I generate core_clk and sysref from an MMCMs driven by one of the Refclks?
trevorr
Hi @apogeedbkxilinx ,
As long as you can meet the timing requirements of the core_clk and sysref signals (as described in PG242) this should work.
https://www.xilinx.com/support/documentation/ip_documentation/jesd204c/v4_2/pg242-jesd204c.pdf
However, we recommend using an external device for this operation as relying on the internal MMCMs can introduce unwanted latency.
I hope this information helps, and please let me know if you have any further questions.
Trevor Rishavy
Xilinx Product Application Engineer
trevorr
Trevor Rishavy
