JESD204b GTY transceivers
I am attempting to set up JESD204 PHY and am unable to select GTY transceivers under "Transceiver Type". The device I am using is the XCZU19EG-2FFVD1760E. I am able to select GTY for other transceiver base IP such as Aurora 64/66. Can anyone offer some insight on this?
Dan
Re: JESD204b GTY transceivers
This works for me.  What version of Vivado are you using?
Thanks for the reply, I am using Vivado 2017.3
Was this resolved?
I am on 2018.3.  Using Jesd204 core (7.2) with phy and shared logic included and cannot select GTY under the 4th tab "jesd204 phy configuration"  I am also using the ZU19eg device.
Ok, I may see part of the problem.  When placing a jesd204 (7.2) ip in a bd. the GTYE4 is grayed out.  If I just instantiate the IP outside of a BD design I can select GTYE4.  Why?  How can i fix this?
