07-11-2013 08:31 AM
a very simple question, but I can't find a solution:
during synthesis and place&route every- time I got the critical warning that no clock-constraint is present for the clock-inputs of he FIFO => where can I edit the clock-constraint for the FIFO?
Best Regards
Bodo
07-12-2013 04:16 PM
The core clock constraint is sourced by the .xci file automatically. If you need to edit the constraints (which seems you do), you can find the constraints at:
<project_directory>/<project>_srcs/sources_1/ip/<core_name>/<core_name>/<core_name>_*.xdc.
There will be three .xdc files (depending on your configuration).
It seems that you just need to issue a "create_clock" constraint on the clk source nets.
Chris
07-11-2013 02:42 PM
Can you post the actual warning? Normally clocks are constrained at the top level of the design,
so the only additional "constraint" you need for a FIFO is the clock ratio between read and write
clocks, and then only if your core uses the built-in FIFO logic.
07-12-2013 12:01 AM
attached you will find the actual warnings,
Best regards
Bodo
07-12-2013 04:16 PM
Chris
10-30-2013 02:20 AM
