MIPI DPHY PIN ZCU106
Design Initialization[Netlist 29-160] Cannot set property 'PACKAGE_PIN', because the property does not exist for objects of type 'pin'. ["e:/ISP_VERIFY_ZCU_V6/ISP_VERIFY_ZCU_V6.srcs/sources_1/bd/block_design/ip/block_design_mipi_dphy_0_1/ip_0/block_design_mipi_dphy_0_1_hssio_rx.xdc":119]
Place Design[Place 30-687] Expected cell block_design_top/block_design_i/mipi_rx_sub/mipi_dphy_0/inst/inst/block_design_mipi_dphy_0_1_rx_support_i/slave_rx.block_design_mipi_dphy_0_1_rx_hssio_i/inst/top_inst/bs_top_inst/u_rx_bs/RX_BS[0].rx_bitslice_if_bs be placed along with its associated I/O. Please check if the cell is properly connected to any I/O. Please also check to make sure any BITSLICE in native mode has location constraints.
[Place 30-99] Placer failed with error: 'Placer initialization failed'
Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure.
[Common 17-69] Command failed: Placer could not place all instances
产生原因:数据通道和时钟通道不在同一个Byte-Group中。
解决方法:DPHY生成的bg<>_pin<>_nc引脚需要连接到顶层引脚上,IP会自动约束管脚。
参考PG202 23页中关于bg<x>_pin<y>_nc 引脚的描述。
