OSERDESE3 vs OSERDESE2 TQ output
What is the difference (if any) between TQ generation in OSERDESE2 and OSERDESE3 (Kintex-7 vs. Kintex Ultrascale)?
ug571-ultrascale-selectio.pdf document shows two attributes OSERDES_D_BYPASS and OSERDES_T_BYPASS, but they are not mentioned in ug974-vivado-ultrascale-libraries document.
Thank you.
Hi @arotenst
Yes there is no difference , both drives the tristate input of output/Inout buffer.
Hi @arotenst
OSERDES_D_BYPASS and OSERDES_T_BYPASS attributes of OSERDESE3 are internal to the VIVADO and not to be used when you instantiate the OSERDESE3.
T input for the OSERDESE3 is to be driven from fabric, this is combinatorial tristate . OSERDESE2 for 7 series supports tristate serialization upto 4:1
Thank you for the explanation. Actually, I asked about TQ output. Any difference between TQ generation in OSERDESE3  and OSERDESE2? My feeling is NO, but please confirm.
Thank you.
Hi @arotenst
Thank you.
