QDR2 interface problem with MIG2.0
Dear all ,
       currently i am working on QDR2 and DDR2 interface with Vertex5, for this i used MIG2.0 to generate RTL code,
       i used the code to simulate, in this "call_done" is not goes high at all
       if any one worked on this please help me very urgent
Fhz : 200MHZ
Venkatesan.K
zhex
In MiG2.0, an example testbench is provided. You could run sim.do in mig_20\example_design\sim\ in Modelsim and this will give you a good start and you could then refer to the test bench.
zhex
